Help with Self-Intersecting Sweep around complex path
morgan_utting
Member Posts: 5 ✭
Hi there,
I'm looking to sweep a sketch along the curves of this polyhedron, so that every curve turns into a matchstick. While Sweep lets you do all six sides of a hexagon here, it fails as soon as you click a branching sweep path from there. The error says that it is self-intersecting. I don't mind that it intersects, because it's putting material right where I want it, and it might as well just boolean all swept paths into one part. I know that mathematically it can't handle two of the same thing in the same place though.
One solution I tried is to generate a polyhedron a little larger than the first one, and making and thickening surfaces that bridge between the inner and outer polyhedron, but this is too time-consuming as you have to bridge every matchstick manually.
Has anyone got any ideas about how to turn every line of this polyhedron into a thin stick of material, to make a single part?
https://cad.onshape.com/documents/113dc998982b38225131308d/w/7f0af6aacf07771e89bad19b/e/69a643cf667145898976489a
Try the Pattern & Sweep custom feature.
Example studio:
https://cad.onshape.com/documents/f356676f45bcc59559e2ae32/w/fb04372c15fd09327af64550/e/01182b9cf1...
▚▞▚▞▚▞▚▞▚1
Example studio:
▚▞▚▞▚▞▚▞▚1 -
Wow! Thank you so much Michael! You're the best, that solves my problem more perfectly than I even thought could be possible. Colour me impressed. Learning something new every day.
God Bless,
Morgan1
