Version Management
brooke_goetschbrooke_goetsch Member Posts: 3
Hi all,
I have a relatively simple assembly to model, less than 10 components. I'm wondering if there is a better way to keep track of this model than what I have done so far.
For some context, the assembly is a model of a 2'x4'x2' fiberglass planter. My company buys this off the shelf, with a few customizations. Upon receipt we make our own changes, drilling holes mainly. The problem is that this base planter is used for two different subassemblies of our overall product. The steps to 'prep' the containers are different depending on the use case, ex. holes will be drilled in different spots.
How I have managed this in the past is creating a two different versions for the container, then referencing them in their relevant subassemblies. This has caused some pain for me as I was not aware that once you version something you cannot edit that version. So now that we have updated some plumbing fittings within the base container assembly (that is later transformed into two other subassemblies for the final product) I have to go through that versioning process again, there are already about 8 different versions.
I'm wondering if there are better ways to manage this so that is not such a hassle when a small part of the base assembly is updated. And especially to minimize clutter. Happy to provide more context as needed, that was kinda confusing lol.
Thank you :)
  • glen_dewsburyglen_dewsbury Member Posts: 1,256 PRO
    @brooke_goetsch
    I don't think versioning is applicable for what you're trying to accomplish for the reasons given in your description. Part configurations will allow separate hole patterns for flexibility and still allow changes. Each configuration will be derived from the purchased item and given its own part number.
    Versioning is for keeping milestones in your design process but they are permanently fixed and are not editable.
    https://learn.onshape.com/catalog?labels=%5B%22Self-Paced%20Courses%22%5D&values=%5B%22Configurations%22%5D
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,046 PRO
    Plus one for configurations. You would model all the possible holes, and then configure them as suppressed or unsuppressed as needed.
    When you insert the planter into an asm, it will ask you which configuration you would like to use.
    Another way is to create branches. Have one branch for one type, a second branch for another type, etc.
     In this case though, configurations is definitely the best way.
