Is it possible to separate the text (value) from the dimension line?
DURAFIXDURAFIX Member Posts: 2 PRO
En dimensiones encadenadas pequeñas a veces es necesario separar el texto de la línea de dimensión y conectarlo con una línea indicativa, pero no sé cómo hacerlo.
  • MichaelPascoeMichaelPascoe Member Posts: 2,818 PRO
    edited November 2023
    Hi @DURAFIX, as far as I'm aware, this is not currently possible. I've needed this functionality multiple times though. There are some work arounds, but they are not easy if you wish to keep the dimension live.
    If you like, you can create an improvement request here.
    RENDERCAD
