How to change the color of a singular imported part in assembly?
annamaiannamai Member Posts: 2
I'm making a 3D Minecraft Poppy using blocks, and I just finished it but now I want to change the color of each block. Is it possible to change the colors of the blocks in assembly since all the blocks are the same imported part?
  • MichaelPascoeMichaelPascoe Member Posts: 2,744 PRO
    It is possible to add the "Appearance" property to the assembly BOM panel on the right side of your screen.
    However this will only let you change one at a time.
    You could perhaps create an in-context part studio of the assembly, then Transform copy all of the assembly parts into the In-context part studio. This would allow you to change the color of more than one at a time.
