spindle rework
iain_downsiain_downs Member Posts: 38 ✭✭
Hi, all.
I'm new to onShape and mainly new to CAD (and a hobbiest - so amateur all round)!
I'm trying to design a lathe spindle.
I've got a series of extruded, concentric cylinders, which is fine, but I now want to make some changes.  Specifically, I want to reduce the diameter of *part* of one of the cylinders (to allow for a smaller bearing at the back).  The options I see are to split the cylinder across and deal with each half (e.g. reduce the diameter of one half, to split the cylinder at a sketch and insert a new extruded circle (cylinder) between the two components or to 'thin' part of the extrusion.
I can't work out how to do any of these!
Or some other way.
Any help much appreciated
Iain
    edited December 2015
    @iain_downs
    If you have modelled the spindle from scratch in Onshape, you can simply edit the relevant sketch and change the diameter of the extruded circle.
    If you have imported a spindle modelled elsewhere, click on the cylindrical face and invoke "Move Face/Offset"
  • iain_downsiain_downs Member Posts: 38 ✭✭
    Thanks.
    Iain
