How to Warp an Image
cyrus_costa541cyrus_costa541 Member Posts: 56 EDU
I uploaded an image for a drawing however it is not exactly to scale. How do I change its scale, horizontal to vertical ratio, in onshape.
    Use the Scale function of the Transform feature. If "Scale uniformly is unchecked" XYZ can be scaled independently to change the size and ratios.
  • martin_kopplowmartin_kopplow Member Posts: 1,306 PRO
    @mahir How do you select an image as "Entities to transform or copy" in this dialog? It will not accept images if I try.
  • S1monS1mon Member Posts: 4,063 PRO
    As far as I know, there's no way inside standard Onshape to do non-uniform scaling of an image. You can't even use the transform feature on a sketch. The transform tool within the sketcher can only do uniform scaling.
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,611 PRO
    When you insert a sketch picture you can apply dimensions to it, however if you want more control, you can try this "Image" FeatureScript, that lets you change the aspect ratio and use a reference on the picture to apply a scale:
    https://cad.onshape.com/documents/f7a45d78c374497d37c1d2cb/v/9fcdb7ff58bfb8a042a7288c/e/557019cd8b843cc475681faf?jumpToIndex=1436
    Lol completely spaced that this was for an image. But like everyone else said, Onshape isn’t really made to edit images. However, there are a ton of free image editing programs out there. And they all can do image stretching. My go-to is usually Paint.net.
