Sweep on cut corners
sebastian_skaliksebastian_skalik Member Posts: 2 EDU
I'm trying to do a sweep on the cut corners, but I can't. On rounded edges, the problem does not occur, but when I set Fillet:
Control: Conic
Radius: 4
Rho: 0.01,
I cannot do a sweep. Photo of the problem below. Please help me how to do a sweep in such a situation.
Project: https://cad.onshape.com/documents/436a2fdce3f98e6b03c80f73/w/76a5bc011ba628dd448a88fe/e/aefab324c01fabab49ee44bd?renderMode=0&uiState=656496f5a8f8e14e513dbc37
  • S1monS1mon Member Posts: 3,834 PRO
    You shared via link so it's not possible to copy the document to see what the problem is.
  • martin_kopplowmartin_kopplow Member Posts: 1,141 PRO
    The sweep says:
    Also, it is not clear what you want to achive. The sweep would add nothing to the part, and if it was done to remove material, a move face or a split would be easier.
