Boolean Resulted in no Geometry Change
cyrus_costa541cyrus_costa541 Member Posts: 56 EDU
When I try and boolean two faces I get something that says that "Boolean resulted in no geometry change. Either the parts do not fully intersect or they are not fully contained. However I have looked at the lines I am using and they are using the exact same lines and the only gap I see seems to be due to the imperfect graphics of onshape. I am not sure what to do.
Below is a link to the model.
 https://cad.onshape.com/documents/fd607866cf7bb929780c1d65/w/9c8d461f2e6c1d2e687a7e1d/e/eed64e90f2f8012c4f566e48?renderMode=0&uiState=65659f2203b7ea273b2b96a9
The two faces I am trying to join are the light blue and grey faces and the intersection is circled in red in the image below.
