Part Update - How do I update a revised part?
scott_harrisscott_harris Moderator, Onshape Employees, csevp Posts: 66 image
Sorry if this has already been discussed. As I change parts in Part Studio, I can not find the way to update the workpiece in CAM Studio. What am I missing?
/Scott
PS. Pico can't find it either.
Scott Harris / Onshape, Inc.
  • scott_harrisscott_harris Moderator, Onshape Employees, csevp Posts: 66 image
    Also...  a workpiece should maintain it's part name when brought into CAM Studio...
  • John_P_DesiletsJohn_P_Desilets Onshape Employees, csevp Posts: 262 image
    @scott_harris  Just to clarify, are you trying to edit the stock definition, or update the part you changed in the part studio to cam studio?
    To update a part in CAM studio you need to first create a version. Next, go to the components page and click the blue icon of the part.
    If you need to edit the stock definition, you will need to edit the job and change the stock size. Does that answer your question?
    Hi John... Yes. I am trying to update the part, not the stock. Thanks for the tip... it works fine.
  • joe_dunnejoe_dunne Onshape Employees, Developers, csevp Posts: 198 image
    Officially the update is not fully supported yet.  It kind of works..  The goal very soon will be for it to update exactly like drawings.  You tell CAM Studio to use the newer version. and the toolpaths will update appropriately . .that project is being worked on now...
    Joe Dunne / Onshape, Inc.
    Thanks Joe. An indicator that the model is out of date (like drawings) is extremely valuable.
