Placing a cut (or split) into a hollow cylinder
New to OS!
I have a 3mm wall thickness hollow cylinder that I need to place a 2mm cut into its length.
https://cad.onshape.com/documents/b1ae7e9903ea8fbfb129c71d/w/d57403c52e6cf51e014a1699/e/b80918c455e0839f23451806?renderMode=0&uiState=656dd479ead1c41de556ce92
This plate is to go over a pole with a clamp that goes around the cylinder to hold it in place. Im struggling with adding the cut into the cylinder that will allow it to clamp onto the pole properly.
Many thanks
Many thanks
