Removing more than one constraint
Henk_de_VlaamHenk_de_Vlaam Member, Developers Posts: 267 ✭✭✭
During sketching, a different approach sometimes requires that a lot of constraints have to be removed. Is it possible to do that in one go?
  • S1monS1mon Member Posts: 4,052 PRO
    One very useful trick is to use the sketch transform tool to grab one of more entities and move them. It will automatically remove whatever constraints are tying the entities down while retaining any internal constraints. You can then transform again to move stuff back into place, and only add back constraints you really want.
  • Henk_de_VlaamHenk_de_Vlaam Member, Developers Posts: 267 ✭✭✭
    Thank you @S1mon.
    That's a very usefull trick.
    But moreover, it would be appriciated when there was an improvement of selecting more than one constraint.
