wrap misalignment
damir_kucherenko
Member Posts: 2 ✭
in General
Hi everyone,
I faced a behavior of wrap feature that confused me.
I'm not sure if it's a bug so I decided to ask a question first instead of reporting it.
I've created a cylinder and a plane aligned with it's surface
then I created 3 separate sketches with rectangular shapes and all of them positioned on the same distance from the center line but with different size.
I expected that all of them will be aligned after applying wrap function, but by some reason they are not
document:
https://cad.onshape.com/documents/ffbc031eafa46a162e4e271d/w/799e7c087acda3adf22b1623/e/3567f769253baf463a591274
in the "problem" part you can see the issue that I faced
in the "expected" part you can see how I think it should work by placing all rectangles in the same sketch
Am I doing something wrong?
Maybe I got a wrong idea how it should work?
document:
Optionsemmett_weeks Onshape Employees Posts: 29In the absence of manually entered anchor points, wrap generates automatic anchor points by taking the bounding box of all of the tools, getting the center, and then projecting it on the target. If more precise alignment is needed, then manual anchor points need to be provided. https://cad.onshape.com/documents/bb7c6da59b9813d4f730c842/w/070df00caf7da8977cfd3c99/e/046428fd1dad0f3b895b487c is not great from a design perspective, but it does illustrate a way to align the individual wraps.2
Optionsben_bouws Member Posts: 7 ✭Also, I think I figured out what is actually happening that causes them to be offset, because each sketch does not directly intersect the cylinder, when Onshape calculates the wrap it rotates each rectangle about it's center point to make it tangent to the cylinder, and then it is able to wrap each rectangle. Because each rectangle is a different width they each have different center points that they are being rotated about which is what causes them to be misaligned.0
