Sheet Metal: Flat view tab not showing
martin_kopplow
Member Posts: 1,317 PRO
I noticed that the flat view tab is sometimes not available, after I open or switch to a part studio tab with a sheet metal model in it. Everything looks as usual, only the small tab with the unfolded icon on the right side of the model window isn't there. All other tabs are. When I sign off / sign in and open it again, it comes back.
Is that a bug or does it serve a reason?
glen_dewsbury
Member Posts: 1,306 PRO
Seems to be a bug that I see from time to time. Refresh browser seems to bring it back.0 -
_anton
Member, Onshape Employees Posts: 532
If it appears after you reload, it may be a bug. Could you check your browser console when this happens? And contact support with the details so that this gets flagged for us to investigate.0
