2024 Onshape feature wishlist
bryan_lagrangebryan_lagrange Member, User Group Leader Posts: 985 ✭✭✭✭✭
With the last Onshape update of the year in the books what is on your wish list for 2024?
Here is my list:
- Sheetmetal loft
- Onshape CAM
- Improvement/update to LiDAR scan
- Sheetmetal formed features (louvers)
Bryan Lagrange
Twitter: @BryanLAGdesign
  • Ste_WilsonSte_Wilson Member Posts: 582 EDU
    Hmmm.
    Propper dimensions for isometric views.
    Some access to the render studio on the Edu enterprise edition.
    CAM would be nice aswell!
  • GWS50GWS50 Member Posts: 500 PRO
    CAM please
  • martin_kopplowmartin_kopplow Member Posts: 1,315 PRO
    Not yet a list, but one thing: Something that lets us design tangent faces between other irregularily shaped faces easily, AND also at any specified angle ("Banana-Edges").
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,093 PRO
    Faster performance when many features on the same body.
  • GregBGregB Member Posts: 4 EDU
    edited December 2023
    This is a nice challenge and in fact one of the features in our latest release (1.174 on Dec15,2023) can help you out!
    I had a quick crack at it here: https://cad.onshape.com/documents/7110a3509e50f046a1d840fb/w/98ed330e5897a77ab1a158c0/e/45a47a40162d6c29536f54c0
    It's also a really good test case for exploring some of our new measurements and diagnostics tools (face-tangent angle in particular), and also the use of these measurement tools when viewing a cross section.
    Image here is with the connection angle at 10deg. The helper surface I used is hidden, but you can dig it out of my public doc. The connection on the left side is tangent
    Hi @GregB , thanks for trying this. These things sometimes happen, and while I can do tangents with the help of ... well ... helper geometry, I find 'tangent' angles difficult, especially when they are to apply constantly at all places along an edge. The reason I asked for this is that it would be very nice if the angle was just a parameter of the tangency, so there woud be no need to create too much potentially instable helper geometry.
    Linke this, but a bit more elaborate, and on a per path, profile or curve set basis.
  • paolo_ciancipaolo_cianci Member Posts: 25 PRO
    Create section view from a broken view
  • adrian_vlzkzadrian_vlzkz Member, pcbaevp Posts: 304 PRO
    -Part Studio Performance
    -Large assembly performance
    -Parametric Sketches in Drawings
    -Better Interface for Released items (Parts, Assemblies, Drawings)
    -More Enterprise Customization
    -Advanced Workflow customization
    CAD Engineering Manager
  • MichaelPascoeMichaelPascoe Member Posts: 2,817 PRO
    RENDERCAD
  • robert_johnstonrobert_johnston Member Posts: 64 PRO
    Overall improvement to sheet metal features.
    Sheet metal loft - not just for simple planar sketches
    Rip cut on sheet metal between two 3D points or 3D sketch path.
    Close up the relief on the corners.
  • fstfst Member Posts: 79 ✭✭
    A Maker license that contains a limited amount of private documents and CAM. For hobbyists and currently-still-hobbyists who want to iterate on an idea in their free time that, if it turns out well (which is still very uncertain) might be worth to manufacture and sell in at least small batches.
  • houston_lucashouston_lucas Member Posts: 3
    Now that we can make folders in the process tree, it would be nice to have the option of hiding all or supressing all in the folder. instead of selecting all manually
    This, a thousand times this.
    YES!
    Proposed behaviour: On hiding a folder, all items inside get hidden, on unhiding it, it does NOT unhide all inside, but returns to the state before hiding. That way, unhiding a folder wouldn't unhide all the stuff inside that was hidden for good reason (like helper geometry, sketches, etc.). Only explicitely unhiding an unhidden folder again would unhide all inside. (That wasn't my idea, it is basically a proven standard in other CAD systems.)
  • blake_owenblake_owen Member Posts: 3 PRO
    Need a button on the left side of the screen that allows to filter for the latest released items only (similar to the "Released Drafts" button) and then filter for drawings select all the drawings in the assembly and click export and get all the latest revisions of the drawings in one export
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,621 PRO
    Have you tried switching to the "list view" instead of "Document view" when browsing a folder?
