joining edges on dxf
kevin_mason558kevin_mason558 Member Posts: 64 PRO
i have downloaded a dxf of parts for a model to be cut out and made.
i was wondering if there was a way of joining them together to create the model online. to see it in 3D
imported them into part studio and extruded them into sheet metal parts.
is there a way to join curved edges of parts to each other? i have a load of flat parts but they will be welded together and bend/ buckle themselves to fit.
 can i join edges of parts or would it need to be redrawn in 3d
  • martin_kopplowmartin_kopplow Member Posts: 1,169 PRO
    You can do quite some complex shapes in sheet metal and then also assemble these parts, but bending a flat part after the fact is AFAIK not possible.
