opEnclose new option to keep redundant edges. No definition key identified in the std library
Jacob_Corder
Jacob_Corder Member Posts: 141 PRO
With the new release, there is an option now to keep redundant edges for opEnclose. However, the std library does not identify what the key is to the definition.
Does anyone know what the key to the definition is so I can implement this?
This is the definition in the std library.
 * Takes in a set of bodies and faces and creates solid bodies for the enclosed regions.
 * @param id : @autocomplete `id + "enclose"`
 * @param definition {{
 *      @field entities {Query} : Bodies and faces for enclosure.
export const opEnclose = function(context is Context, id is Id, definition is map)
    return @opEnclose(context, id, definition);
Thanks
  • Jacob_Corder
    The response I received from onshape support is that this is behavior is automatic and no definition key is required. Simply upgrading to fs version 2221 enables this new functionality.
  • Jacob_Corder
