<p>Welcome to the Onshape forum! Ask questions and join in the discussions about everything Onshape.</p></p><strong>First time visiting? Here are some places to start:</strong></p><ol style="list-style:inherit;margin-left:25px;"><li>Looking for a certain topic? Check out the <a href="https://forum.onshape.com/categories">categories filter</a> or use Search (upper right).</li><li>Need support? <a href="https://forum.onshape.com/post/question/community-support">Ask a question</a> to our <a href="https://forum.onshape.com/categories/community-support">Community Support</a> category.</li><li>Please submit support tickets for bugs but you can request improvements in the <a href="https://forum.onshape.com/categories/product-feedback">Product Feedback category</a>.</li><li>Be respectful, on topic and if you see a problem, Flag it.</li></ol><p>If you would like to contact our Community Manager personally, feel free to <a href="https://forum.onshape.com/profile/6/LouGallo">send a private message</a> or <a href="mailto:lgallo@onshape.com">an email</a>.
</p>
</p>
Tutorial, Step Stool, Step 8, extrude/remove or pocket leaves a thin wall
ali_e280
Member Posts: 10 ✭
Hi,
I'm trying to complete the the step stool exercise. The instructions are to create on offset on the face and use extrude/remove to create a 5 mm indent. When I apply the remove extrude, I get an unexpected thin wall. This thin wall prevents the shell step following this step.
SKETCH
EXTRUDE OPTIONS
PART WITH THIN WALL
What step am I missing here?
Thanks,
Ali
Because the sides of the part are drafted (at a nonzero angle with respect to the vertical), and you're extruding straight down, you'll get a really thin wall with a triangular cross-section.1
Hello. It looks like you've selected the wrong sketch area for the extrude. I read the intent in the design is to create a depression on the step surface in order to have a corrugated surface for traction. The sketch area you selected is the 5mm perimeter. I believe you need to select the large inside area of that perimeter. - Scotty
1 -
Thank you. Looks like you were right about the intent of the exercise, but the question still remains, why is there a thin wall if I remove the 5mm area around the part?
Thank you. Looks like you were right about the intent of the exercise, but the question still remains, why is there a thin wall if I remove the 5mm area around the part?_anton said:Because the sides of the part are drafted (at a nonzero angle with respect to the vertical), and you're extruding straight down, you'll get a really thin wall with a triangular cross-section.
Thank you for the explanation.
