If you would like to contact our Community Manager personally, feel free to  send a private message or an email.
Adding relation ranges in assembly and collisions and physics
 Blåhaj
                    Member Posts: 4 EDU
Blåhaj
                    Member Posts: 4 EDU
                                  in Simulation
                    I'm trying to figure out if there's a way to add ranges for relations in onshape assemblies. For example, trying to make it so if I rotate something 90 degrees it will rotate something else 90 degrees, and when I continue rotating it does not affect any other parts until I get back to 0. (trying to make it so only the first 90 degrees of the rotation has a relation with another revolute mate). I'm also working on some things that I would like to have collisions and/or physics/part interaction. especially gravity or being able to make something elastic. My guess is this isn't possible, but if anyone knows of any feature scripts or applications that allow this please let me know. If not, then maybe this could be a suggestion on things to add to the software unless it's unrealistic. (I don't know much about coding CAD and CAM software).
would this work for you?
