How to remove rotational degrees of freedom in an assembly for rods connected by a ball mate
So this is mostly constrained but the 4 rods can rotate.  Not sure how to fix this.
https://cad.onshape.com/documents/9700f1052eade11e8eadf6ee/w/2250f0f1a1f623da42203c25/e/f933c2192a2b854bade0b8bf
Thanks
  • GWS50
    GWS50 Member Posts: 528 PRO
    In the real world the rods would rotate so perhaps you might need to model it with universal joints at the ends of the rods.
    Alternatively....and this is a cheat and can trip you up when producing the item,,,,,I sometimes model a tiny flat into the bar and set that to be parallel to another fixed face. Not ideal, but gets a quick solution.
  • GWS50
  • martin_kopplow
    martin_kopplow Member Posts: 1,611 PRO
    The question is: How would you want to stop the rods from rotating in the real world?
