Double Threaded Tube - Hole Feature Failure
Nath_McCNath_McC Member Posts: 136 PRO
edited January 2024 in Using Onshape
Hi All,
I have a 100mm long part, which is a bit of a tube (or can be a bar). It has 25mm of right-hand thread on one side and 25mm of left-hand thread on the other.
I currently have an issue using the hole feature. I cannot go through all with the drill and then use the feature again on the other side as the drill hole is already there, and essentially, there is no material to remove. In SolidWorks, I would use the cosmetic thread feature to achieve this.
I would like one call out to be dia 8.5 thru, M10X1.5 RH, depth 25 and the other just to be M10X1.5 LH, depth 25
I have a workaround where I half the drill depth and take 0.1mm off, so 49.9mm in this case, but it leaves a little "V" where the drill tip ends and the callouts look poor.
Would anybody have any solutions?
https://cad.onshape.com/documents/58785ba5e4466167a3ab62db/w/44240a9e6da406118bea177d/e/71dc0b0660dafde4e57588cd?configuration=List_dFYSwtPDwLAK5f=Default&renderMode=0&rightPanel=configPanel&uiState=6593fb83f362903964d421d1
  • bryan_lagrangebryan_lagrange Member, User Group Leader Posts: 997 ✭✭✭✭✭
    This is the best I could get with automatic hole call outs and not manually entering the information with annotation.
    Bryan Lagrange
    Twitter: @BryanLAGdesign
  • Nath_McCNath_McC Member Posts: 136 PRO
    Thank you, Bryan. I will try that way instead.
    You drilled and tapped to the same depth, then added a thru-hole feature.
    Onshape support has logged this as an improvement request as well.
  • martin_kopplowmartin_kopplow Member Posts: 1,319 PRO
    I first thought I'd try to only model one half of the cylinder part, then make the hole and the thread, then either mirror it, or make the other half, boolean unite. In fact this does not work either: The boolean removes the second thread. Strange. Good this is recognized as an enhancement request.
    I believe we need a internal cosmetic thread feature without the holes. Similar to how the external threads work.
