Standard Content - Insert Nuts
a_b873a_b873 Member Posts: 2
I am trying to insert some nuts from the Standard Content library.
As you can see the upper bolt has already a nut.
I select the flange plate and the nut is placed after the existing one.
Then I have tried to select the washer and use "Insert to closest" but the nut will not snap to the washer.
Then I have removed the upper nut too, and I have tried with "Insert furthest from selection", but only one nut was inserted.
I have already 30+ bolts with washers in my assembly. Please advice, how should I batch insert n
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 924 PRO
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,072 PRO
    edited January 2024
    Yes replicate.
    In addition, if all the fasteners are the same, you can make a subasm of the bolt+washer+nut. Set the sub up so that the washer and nut are the correct distance from the head. Fasten that sub once into the top level asm. Then replicate the whole sub at each location.
    That will save you a lot of time and effort.
