Sweeping thread through vertical cylinder
in Drawings
Hi, I'm trying to sweep a helix path through a vertical cylinder to create a threaded hole. Is there any way to limit the sweep removing the parts that are outside the cylinder.
Hopefully this makes sense with the demo
I need to match the rounded thread so I believe the hole tool will not work here.
https://cad.onshape.com/documents/5e1d8db39eb50d3d172df7ff/w/4ed0f327ae312467a1f9561f/e/afdb9685818b0bfeefef66a1?renderMode=0&uiState=659f25091c67c148e68d5b06
