Points along curve
graham_lock
Member Posts: 256 PRO
in General
Hi,
I'm new to Onshape and I'm trying to place points at known distances along a curve to allow me to setup Curve Point planes at those points.
I can place points and set point to point distance but that doesn't give the distance around the curve.
Any help appreciated.
https://cad.onshape.com/documents/b4a598e478a442a901f95f15/v/37c8b35281c273fd047c15e8/e/086f9c8ca51c6bf3f813f908?renderMode=0&uiState=65a133d851170622f59d9f43
Depending on what you're doing, it may even be better to pattern whatever it is you're planning to do with the planes, instead of patterning the planes!
- Dimensions in a sketch could be made along a curve.
- Curve pattern was available in sketches.
- Curve Point Planes in a 3D model could be placed with an offset to another point on a curve, measured along the curve.
- Patterns could be made along a curve with point-to-point or on-curve distance at user's choice.
- The sweep feature had a 'length along path' option.
This might be a good candidate for an enhancement request, since distance on a curve is important and appears to be pretty much state of the art in all other current CAD packages.What I and I guess everyone is looking for is the equivalent of Fusion 360’s plane along path.
https://www.youtube.com/watch?v=B0GLmOJVqho
https://cad.onshape.com/documents/576d1e60c6cb90985345ac37/v/40afeaf7532ba1a17781f6fd/e/0ea78f371cbafb95ea304449
Maybe a bit late the party but just figured this out while working on something else and thought it was worth mentioning...
Here's one way to add a bunch mate connectors (this method also works with the 3d point FS) at specific distances along a path:
https://cad.onshape.com/documents/294f1e87f5207d879a7ab487/w/6d4a055c18c84ce3043cd3a7/e/1f9e8b8d1ffe592f3cec2bbc
The way the multimate connector works you can put both dimensions and 0-1 parameter in the array and it will add MCs accordingly.
