Trying to extrude text but can't filter out inner loops.
jakefrommars64
jakefrommars64 Member Posts: 2 ✭
I am trying to extrude text and am encountering a similar problem to this post (which was solved for them), however after implementing the "qSketchRegion" with filterInnerLoops set to true nothing changed and any letters with inner loops have those loops extruded too. How can I exclude those loops so my "o"s aren't cylinders when I cant query a point in those regions as eventually the text will be parameter driven?
FeatureScript 2221;
import(path : "onshape/std/common.fs", version : "2221.0");
import(path : "onshape/std/geometry.fs", version : "2221.0");
const MARGIN = 0.85 * millimeter;
// annotation { "Default Units" : ["cubicMillimeter", "degree", "degreePerSecond", "footPoundForce", "gram", "meterPerSecondSquared", "millimeter", "newton", "newtonMeter", "pascal", "second", "squareMillimeter"] }
annotation { "Feature Type Name" : "RatioText" }
export const ratioText = defineFeature(function(context is Context, id is Id, definition is map)
    precondition
        annotation { "Name" : "Body", "Filter" : EntityType.BODY, "MaxNumberOfPicks" : 1 }
        definition.body is Query;
        // On which face should the text be shown?
        annotation { "Name" : "Surface", "Filter" : EntityType.FACE, "MaxNumberOfPicks" : 1 }
        definition.surface is Query;
        annotation { "Name" : "Baseline", "Filter" : EntityType.EDGE && GeometryType.LINE, "MaxNumberOfPicks" : 1 }
        definition.baseline is Query;
        // Height of the text (font size)
        annotation { "Name" : "Text Height" }
        isLength(definition.textHeight, { (millimeter) : [0.5, 4, 20] } as LengthBoundSpec);
        // How deep to extrude the text into the object
        annotation { "Name" : "Depth of Text" }
        isLength(definition.depth, { (millimeter) : [0.01, 0.4, 5] } as LengthBoundSpec);
        // Create a sketch on the given plane
        var sketchPlane = evPlane(context, {
                "face" : definition.surface
        var sketch1 = newSketchOnPlane(context, id + "sketch1", {
                "sketchPlane" : sketchPlane
        var cSys = coordSystem(sketchPlane);
        var firstCorner = vector(0, 0) * millimeter;
        var secondCorner = vector(100 * millimeter, definition.textHeight);
        // Create the text and move it to be centered on the part
        skText(sketch1, "textId", {
                    "text" : "Hello World!",
                    "fontName" : "NoboSans-Regular.ttf",
                    "firstCorner" : firstCorner,
                    "secondCorner" : secondCorner
        skSolve(sketch1);
        var bbox = evBox3d(context, {
                "topology" : qCreatedBy(id + "sketch1", EntityType.BODY),
                "cSys" : cSys,
                "tight" : true
        opTransform(context, id + "transform1", {
                    "bodies" : qCreatedBy(id + "sketch1", EntityType.BODY),
                    "transform" : transform(vector(
                                -(bbox.maxCorner[0] - bbox.minCorner[0]) / 2.0,
                                -(bbox.maxCorner[1] - bbox.minCorner[1]) - MARGIN / 2.0,
                                0 * millimeter))
        // Extrude the text
        var sketchQuery = qSketchRegion(id + "sketch1", true);
        extrude(context, id + "extrude1", {
                    "entities" : qSketchRegion(id + "sketch1"),
                    "endBound" : BoundingType.BLIND,
                    "depth" : definition.depth,
                    "oppositeDirection": false,
                    "operationType" : NewBodyOperationType.ADD,
                    "defaultScope" : true
        opDeleteBodies(context, id + "deleteSketch", { "entities": qCreatedBy(id + "sketch1") });
