Help connecting lines on different planes
jake_finley
Member Posts: 2 ✭
Hello I am brand new to onshape and still have alot to learn. I
have a 15x15 frame I'm building and I am trying to add a roof I can add it on the left and right side but all the points in-between. I have no idea how to do it any advice? I am also using beam feature to make all the lines 2x2 square tubing but I have that hidden right now, I can easily extrude the roof but I want to show the actual structure itself
have a 15x15 frame I'm building and I am trying to add a roof I can add it on the left and right side but all the points in-between. I have no idea how to do it any advice? I am also using beam feature to make all the lines 2x2 square tubing but I have that hidden right now, I can easily extrude the roof but I want to show the actual structure itself 0
Second , everything that can be mirrored do so.
Third, try not to design everything in 1 sketch, and allways keep the origin in the centre of your design , makes mirror al lot easier
Final, take a look at the learning center.
