Face Blend help
ilana_kayeilana_kaye Member Posts: 6
I've watched the tutorial yet for some reason I cannot get face blend to work between two planes on different sketches.  Please can someone advise me on what I am doing wrong.
https://cad.onshape.com/documents/3d8b4c3607b806571058888b/w/c645b38ff742c17d3b0e5eda/e/67b322e9c0b99c7e629fcaaf
  • roman_jurt190roman_jurt190 Member Posts: 50 EDU
    hey! it's simple: face blend is a surfacing tool and does not work with solids:) use a standard fillet or design everything with surfaces first and make a solid form it in the end.
  • GregBrownGregBrown Member, Onshape Employees, csevp, pcbaevp Posts: 382 image
    Face blend absolutely does work with solids (solids have faces too!)
    Also, your link is not working, so can you check that so we can take a look at what you've done so far?
