Question on Thread Creator
In my experience it's necessary to use different diameters. Screw threads (external threads) are cut into the cylinder and fit quite well using the intended thread diameter (e.g. 5mm for ISO M5).
Nut threads or internal threads are added to the cylinder surface. It's not logical because the should also be cut out of the borehole.
Currently I use 5 mm for screws and a borehole of 5.4 mm for nuts. Printed with these dimensions, they are fully compatible with ISO M5 threads on metal screws and nuts. Probably varying dependant on your 3D printer and nozzle size. Simply test it.1 -
If you are 3D printing both bolt and nut, is better not to use threadcreator for nut. better subtract the bolt form a full nut with boolean using offset all parameter with a 0.2 offset or similar.
1 -
External and internal thread forms have slightly different specifications, which is necessary to avoid the two threads interfering with each other. See the data in this link:
or run your own searches. If you have access to a library (or a machinist) take a look at Machinery's Handbook which has dozens of pages on various thread forms and their specifications. The data has largely remained unchanged for decades and you can find used copies fairly cheaply in used bookstores or on Ebay.
thank you this helped me a lot. however it won't let me do an offset of anything less than 0.4mm and I'm not sure why
