Driving Tool Path With Sketches
wayne_sauderwayne_sauder Member, csevp Posts: 648 PRO
I think we should have the ability to drive tool paths with sketches. It can be an easy way to force a cutter to do what needs to be done. One example would be the trochoidal tool path. I also think that this particular tool path should have an offset (if I try to use this to mill along the edge of a part I don't want the tool path centered on the edge). I may have missed something here.
  • joe_dunnejoe_dunne Onshape Employees, Developers, csevp Posts: 198 image
    You can drive toolpath with curves... So if you create a sketch in your Part Studio, and then turn it into a composite curve, you can bring it into CAM Studio and use it.
    We obviously want to support sketches directly. But because there is this workaround, we are working on other things first.
    Let me know if that answer is not clear
    Joe Dunne / Onshape, Inc.
  • wayne_sauderwayne_sauder Member, csevp Posts: 648 PRO
     Thanks, Joe,
     I didn't think about trying a curve, I did discover I could use a surface as a work around.
  • Curt_WelchCurt_Welch Member, csevp Posts: 42 PRO
    You can.  Or at least you can drive them with curves.  This is what I have used after being told about it by John.  Create a sketch, then use the Composite Curve tool to create the curve from the sketch lines.  Then, in CAM Studio, you can add the curves as Avoidance components.  In the tool paths, you can then select those curves to drive the tool paths.
  • Caden_SipeCaden_Sipe Member, csevp Posts: 2
    Adding a curve is a good work around. I do hope that it is not the final solution. CAM Studio should work like other CAM software and to be able to detect full chains around an object.
    edited February 2024
    Caden,
    it is a temporary workaround. Also chain/loop select is on the plan too
    Joe
