Extruding from a cylinder and maintaining the curve at the end of the extrusion
mark_green226mark_green226 Member Posts: 6
I'm designing a part that has a push button 5mm out from the side of a cylinder, but I want the top of the push button to have the same curve as the cylinder. So I can extrude a circle out from a sketch plane at a tangent to the cylinder, but that has a flat top.  I can use the wrap tool to wrap a circular shape on the cylinder but that doesn't have parallel sides.  I'm sure this is easy, I just can't figure it now.
Many thanks
