Importing DWG as base sketch
brian_rupp
brian_rupp OS Professional Posts: 13 PRO
edited May 2016 in Community Support
I try importing a DWG and I can view it but I can't use it as a base sketch for a new part in Onshape.  Anyone successful at this yet?
  • anthony_cross
    anthony_cross Member Posts: 2 ✭
    Hello,
    A possibility of automatic constraining or dimensioning an existing sketch would be really useful in such situations. Is there a tool for this in Onshape? I can't find anything. I know you can always fix each line to a current position, but sometimes I'd like to have some flexibility with it...
  • bradley_sauln
    bradley_sauln Moderator, Onshape Employees, Developers Posts: 373 image
    @anthony_cross when you insert the dxf or dwg into a sketch the dimensions are scaled 1:1 so the dimensions are correct but I do see the desire to auto constrain.
    Twitter: @bradleysauln
