Unable to select surface between two offset splines
kristijan_novoselickristijan_novoselic Member Posts: 2
Hi,
you can see the sketch I'm having issues with here (Part studio named "Problem"): https://cad.onshape.com/documents/b2daf18eb1a36f4bd436b313/w/f99d877eb6b9d589999c74d1/e/1da734e36565bb2826e0b872?renderMode=0&uiState=65b0be6300aea5332e37360d
I have a sketch which uses spline from another sketch. Then I offset this spline in two directions. I'd like to be able to select the two resulting surfaces, however I'm only able to select one. Selecting the first surface works as expected:
However, when I try to select the surface between the first one and the inside of the smallest curve, I can't do it. It always selects everything:
What am I doing wrong? Any idea how to fix this?
  • lanalana Onshape Employees Posts: 746 image
    Spline Trace sketch is blocking selection . If you hide it - it all works:
