Split Object Using Spline?
Hi all,
I'm struggling to figure this one out. I need to make a curved cut to an abnormal shape and the most obvious way to me would seem to be to use a spline (which I've successfully drawn) to cut the shape, but neither the extrude (remove) or split functions seem to be able to utilize the spline I created. Can anyone provide guidance on how to accomplish this?
https://cad.onshape.com/documents/bdadf3f007f9d7d1dd039277/w/baf2a86ccb085f0f9746f0b6/e/49603e98386a2e970679e2a8?renderMode=0&uiState=65b1a346d3a0687bd6cb6a4a
Thanks in advance!
Ed
Thanks in advance!
Ed
https://cad.onshape.com/documents/d7a4ab7c04566a64996e8242/w/908898d1424d98f9e166b8d1/e/6fdc2216034fc32101cd508b
Thank you very much for the guidance! This is definitely going in the direction I'm looking for. However, I'm noticing that this process creates a sort of divot near the apex of the curved spline. Any way I can keep that from happening and have the angle be consistent?
