Help with properly animating a worm gear
kael_ckael_c Member Posts: 3 EDU
I cant seem to find the correct Relation ratio using the gear mate, i am using a 4 tooth worm gear with a 20 tooth spur gear. What kind of math should i use to figure out the Relation Ratio?
Document Link:
https://cad.onshape.com/documents/04b65753b634fccee6d83cbd/w/80cd83a296b18682ca372a64/e/aa1c4ccd267c8dfdbf49ded0?renderMode=0&uiState=65bbd2c79a94840854f443d1
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 942 PRO
    That's a weird worm gear, so it's hard to calculate the pitch, but it's something like 4.8 mm in your assembly.  And the pitch diameter of the other gear is 40 mm.  So the gear ratio would be 4.8/(pi *40) = 0.038.  Or it might be the reciprocal of that, 26.18.
  • kael_ckael_c Member Posts: 3 EDU
    Thank you very much, i'm just messing around with gears and animating right now.
