adding non-planar holes into a curved surface
Andrew_Netherton
Member Posts: 21 PRO
I am trying to figure out how I would put a series of holes into a curved surface. The surface is a flange off of an inclined plane that is at an angle with respect to the axis of the curve. You can see an example in the model below:
https://cad.onshape.com/documents/137547d8c29926caf9a25cff/w/fae9d09a918dbffcb6e6d8d1/e/007b84dfa9b77331494d0c4a
I am trying to put radial mounting holes for an exterior panel on the orange face that are at the midpoint of the flange at their location.
So far I can't see any way but to do each one individually, but I have to imagine there's a better way I simply don't know about. (Been on Onshape professionally for only 5 months now.)
glen_dewsbury
Member Posts: 1,251 PRO
https://cad.onshape.com/documents/fde7beb02d869a73f1d45706/w/9557b07e898fd3b84dbbe29a/e/9ca6f11ac19caf00147c80d9
https://www.youtube.com/watch?v=B0GLmOJVqho
I'll fully admit that the sample I gave was simplified, but I figured it was close enough - maybe not!
Did you view the video S1mon posted? Greg Brown's videos are very helpful.
I've just discovered that I had to flip the direction of the geodesic offset to get my curve on the correct face. Perhaps now I can progress further!
What I'm attempting now is going inside-out, starting on the inside of the flange and going out, only because the panels on the outside are not being very accepting of my offset curves. Better to go from the inside and "through all", I figure.
If there's not enough context in the image, the axis of the hole is severely angled compared to the flange face. The fact that it's not going all the way through I can manage, but the angular misalignment is a head-scratcher.
Note that in my original hole pattern I used 2 offset curves then added a 3d fit spline between the 2 ends. 3D fit spline with only 2 inputs is a line. The end of the line was used as a mate connector for the hole. That made it perpendicular to the face at that point. See sketch 7 for second curve.
Thanks for the assistance everyone!
I had another go at this after seeing the problem you still had with holes not normal to surface and came up with this. Hope it helps.
