rotate a plane?
I'm pretty new to Onshape. I managed to build a part that is very close to what I'm after. I only need to rotate the extrusion named "Face" 1 degree to be more vertical from the side view. I don't see any way to rotate a plane after it's been created, is there? Every time I try to make a new plane and rotate it, and then use it on an existing sketch, the sketch gets severely out of place. I've spent over an hour trying to figure this out and I figured someone here would have a suggestion. Here is a link https://cad.onshape.com/documents/e2666ce622b079bff9fae628/w/12d6445955ad699041c25e86/e/4419fb2d16b6fb8c4da3ead7?renderMode=0&uiState=65bffcd4ff3dbf4449f5d1ff
thanks
