rotate a plane?
scott_depace
Member Posts: 9 ✭
I'm pretty new to Onshape. I managed to build a part that is very close to what I'm after. I only need to rotate the extrusion named "Face" 1 degree to be more vertical from the side view. I don't see any way to rotate a plane after it's been created, is there? Every time I try to make a new plane and rotate it, and then use it on an existing sketch, the sketch gets severely out of place. I've spent over an hour trying to figure this out and I figured someone here would have a suggestion. Here is a link https://cad.onshape.com/documents/e2666ce622b079bff9fae628/w/12d6445955ad699041c25e86/e/4419fb2d16b6fb8c4da3ead7?renderMode=0&uiState=65bffcd4ff3dbf4449f5d1ff
thanks
thanks
https://www.onshape.com/en/resource-center/tech-tips/tech-tip-sketching-with-onshape-mate-connectors
Senior Director, Technical Services, EMEA0 -
I looked at the mate connector article and tried with no success. Not sure how to use that feature.
Try this one then https://www.onshape.com/en/resource-center/tech-tips/tech-tip-5-things-you-can-do-with-mate-connectors-in-onshape-part-studiosSenior Director, Technical Services, EMEA0
@scott_depace I'm not exactly sure where your three points are coming from in this document to form the plane, but if you want to control the angle of a plane a mate connector will be your best bet like Neil said. If you make your document public it would be easier to see what is going on.
