How to stretch part diagonally
Is there a way to have a part and then shift one side down to change the part? For example, if you have an extruded rectangle, could you shift one side down to transform it into an extruded parallelogram (as shown in the picture below)? I cannot do this in the sketching part of the design. Any help is much appreciated.
  • matthew_stacy
    matthew_stacy Member Posts: 489 PRO
    @thomas_fieguth, the "Move Face" tool will accomplish the task that you describe (example):
    1. Select top and bottom faces of the Part
    2. Select ROTATE (alternates OFFSET & TRANSLATE)
    3. Select an AXIS to rotate about
    4. Specify the ANGLE of rotation (and direction)
    However I encourage you to question your assertion that, "I cannot do this in the sketching part of the design".  Editing the sketch, is generally the superior method and a better modeling practice.
    1. Delete the HORIZONTAL constraint (top of rectangle)
    2. Delete PERPENDICULAR constraint
    3. Drag the rectangle into a parallelogram.  Better yet dimension the angle, to fully constrain the sketch (good engineering practice)
  • dirk_van_der_vaart
    dirk_van_der_vaart Member Posts: 561 ✭✭✭
    edited February 2024
    That,s possible, you will have to delete the Perpendiculer constraint on all four corner,s.
    Have a look at the help file.
    https://cad.onshape.com/help/Content/constraints.htm?Highlight=Constraints
    But it will be much easier to draw the sketch with an angle in the first place, define the angle and can change it whenever you want
  • matthew_stacy
  • thomas_fieguth
    thomas_fieguth Member Posts: 10 EDU
    Right. The move face tool was what I was looking for.
    I should have been more specific about the "I cannot do this in the sketching part of the design" statement. The example I gave was an oversimplification of my problem for the sake of clarity.
