Cannot use Exploded View with Named Views on Drawings
Cihan_YanenCihan_Yanen Member Posts: 2
Right now I can only create exploded views from the default isometric camera angle, because the selection for the exploded view and the named view are at the same place. Is there a way I can do that right now? If not, can we get separate selection for exploded views and named views so we can create different angles for exploded views?
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,086 PRO
    edited February 2024
    Do you mean on the 2D drawing? These two boxes are the setting. The actual orientation is created while in the 3D assembly.
