Importing data points form a CSV file
stefan_thullner960
Member Posts: 2 ✭
Hello,
I would like to use the 3C CSV Feature Script to import point coordinates from a CSV table. It does work for CSV tables with only integer values. However, I would like to import a list of float points. In that case it tells me "3D CSD 1 did not regenerate properly: Error regenerating.".
What can I do to still import my points?
With lists like this it works:
0,0,0
1,1,1
2,-1,2
3,2,3
4,-2,2
5,3,1
6,-2,0
7,2,1
8,-1,2
9,1,3
With lists like that, I receive that error:
1.775,2.625,2.500
1.781,2.619,2.584
1.793,2.607,2.668
1.824,2.576,2.754
1.879,2.521,2.831
1.947,2.453,2.875
2.061,2.339,2.910
2.200,2.200,2.920
2.200,2.200,2.920
Thanks already for your help!
Hey Stefan,
You may have already figured out this issue, but I suspect the problem is that you have several duplicate points (the last two points are identical). This will throw an error when the feature tries to fit a spline through the points (opFitSpline). I've found the 3C CSV definitions to be more cumbersome than helpful - so I wrote a different feature that will take a csv and create a spline through the points - no need to define start rows or columns. That feature is here: https://cad.onshape.com/documents/ceb23a125beb3f2c034b0c2b/v/552ec7ba6859d122ff061ec8/e/ad6a6423b0183ca1fd9c53bd
Cheers!
-j1
