EXPORT BEND TABLE TO CSV
Cary_Bettenhausen
Member Posts: 49 PRO
Our company has successfully implemented the Stock Size FS discussed here: https://forum.onshape.com/discussion/comment/77847#Comment_77847
Now we would like to take this one step further by getting info out of the bend table for SM parts. Is there a way to do this or is this in the works?
Thanks,
Cary
Thanks,
Cary
1
But with featurescript you have some options.
In this sample, I can retrieve all of the bend information for a given sheet metal model.
You could make a FeatureScript that outputs to the featurescript notices tab a CSV of all the information you require.
https://cad.onshape.com/documents/90c254d38958666d2f26de12/w/471128694634b8d0cd6861a7/e/d96d308fb24c30b79fbcac89
The better option would be to make a custom featurescript table, and Onshape provides an export to tab separated value file format option for custom tables (its the copy table button).
https://cad.onshape.com/documents/8d8bfeacb2264501db61fd2c/w/98c93d8edff2d143c1a5805a/e/77843f0e440dade9e2751bc1
You could also do it with the API, and put a nice button in Onshape that does a "export bend table to csv". But that would require a lot more work than any of the featurescript options.
