remove a body in featurescript
rooiejoris
PRO
As I start always: I am not a programmer, but I think I want something fairly simple:
I want to remove all bodies with a volume smaller than X
the println works so the condition works as well, I just can't get it done that it actually deletes the bodies.
documentation says something with opDeleteBodies, but I can't figure the right arguments/values/whatever
you can see the script in the second tab of https://cad.onshape.com/documents/bced954384551d9a45056666/w/1c4ec0f34b9d2439e54967bb/e/efbe92356f7e4fdb9a7ffea8?renderMode=0&uiState=65cc8eb5ce42ed723b91737c
thanks in advance...!!
cheers / joris
FeatureScript 2260;//import(path : "onshape/std/common.fs", version : "2260.0");
import(path : "onshape/std/geometry.fs", version : "993.0");
annotation { "Feature Type Name" : "remove_larger_volume" }
export const myFeature = defineFeature(function(context is Context, id is Id, definition is map)
precondition
// Define the parameters of the feature type
//println("dit is het begin");
println("start");
setVariable(context, "test", 1); // test
// Define the function's action
for (var part in evaluateQuery(context, qAllModifiableSolidBodies()))
//var partName = getProperty(context, { "entity" : part, "propertyType" : PropertyType.NAME } );
var volume = evVolume(context, { "entities" : part });
//volume = volume;
println(volume);
if (volume <= 0.0002 *meter*meter*meter) {
println("tada");
opDeleteBodies(context, id + "deleteBodies1", {
"entities" : entity
println("end");
});you can see the script in the second tab of https://cad.onshape.com/documents/bced954384551d9a45056666/w/1c4ec0f34b9d2439e54967bb/e/efbe92356f7e4fdb9a7ffea8?renderMode=0&uiState=65cc8eb5ce42ed723b91737c
cheers / joris
when in the loop every context operation with id should have unique id, so you need to use iterator variable to build the id:
for (var i, part in evaluateQuery(context, qAllModifiableSolidBodies())) {
opDeleteBodies(context, id + ("deleteBodies" ~ i), { "entities" : entity });
}At some moment you will want to perform multiple operation in the loop, in this case it might be more handy to construct the id of the whole iteration first:
const id = id + "iteration" + i; // the id from the outer scope is shadowed here for the scope of the for loop
opDeleteBodies(context, id + "deleteBodies", { "entities" : entity });
//another op_ functions with id here
}Also in your case I would do it in slightly another way:const toDelete = evaluateQuery(context, qAllModifiableSolidBodies())->filter(function(body){
const volume = evVolume(context, { "entities" : body});
return volume <= 0.0002 *meter*meter*meter;
->qUnion();
if(!isQueryEmpty(context, toDelete)) {
"entities" : toDelete
else{
println("No bodies below the volume limit");
Have you tried using" "entities" : part in the opDeleteBodies (instead of entity)? I think that should work as it should be the same entity you just did "evVolume" on...0
Yes, But then I get a warning: @opDeleteBodies: Duplicate id in context: F27r4Cn5tpu5qC7_6.deleteBodies10
->qUnion();
else{
THANKS A LOT! It works...!
thanks for the explanation, I will try to understand it more, but if you don't program that much it is a bit dazzling.
I didn't try the suggestions for the for loop, but tried you suggestion.Also in your case I would do it in slightly another way:const toDelete = evaluateQuery(context, qAllModifiableSolidBodies())->filter(function(body){
->qUnion();
else{
Didn't work first, but that was because I didn't import the right things in the beginning:
this works:
import(path : "onshape/std/common.fs", version : "2260.0");//import(path : "onshape/std/geometry.fs", version : "993.0");
this doesn't//import(path : "onshape/std/common.fs", version : "2260.0");import(path : "onshape/std/geometry.fs", version : "993.0");
and this also notimport(path : "onshape/std/common.fs", version : "2260.0");import(path : "onshape/std/geometry.fs", version : "993.0");
thanks again!!
cheers / joris1 -
Imports from STD of version 993 are very old, the functions that are used in last example were not there yet so importing the latest version of geometry.fs and using the latest version in FeatureScript ____; is a generally good practice.
1
