Rehome (re-own) a Mate Connector to a Part
Jonathan_HutchinsonJonathan_Hutchinson Member Posts: 145 PRO
I have a part which has been derived and had some extra operations performed on it. What I've noticed (and there is a forum topic somewhere that noted this), is that performing something like a Split, or an operation which creates multiple parts, then eliminates the Mate Connector -> Owner Part relationship. I get it, there has to be only one owner to a mate, right.
I would suggest (and request one of the two behaviours; maybe they're available already?
  • Make it possible to use an existing mate connector and 're-home' it to a part as a feature. I can kind of do this with FS, at the risk of creating a duplicate in-place mate on top of one that is existing. But not a super nice solution.
  • I don't know if some sort of dynamic feature would be possible whereby you can select which should be the designated owner part in a situation where ownership is having to be redecided (or, eliminated, as is the current behaviour).
  • On a side note, should operations (such as split) on parts that are owners of mates, where the owned status is about to be lost, maybe have a nice helper status balloon notification as is typical in some features to warn that this status is to be lost? Or maybe have the yellow mark on the feature (so it's warned but not failing with red).
The nicer and more elegant solution I think, which is sort of in between, is to use an existing mate and re-own to a part. But I don't see any capability to do that via FS (only opMate).
Thoughts?
  • MichaelPascoeMichaelPascoe Member Posts: 2,742 PRO
    edited February 2024
    If you need both sides, you could duplicate the part with Transform. Then instead of splitting, you could Extrude remove half of each part, this way the mate connectors stay with their owners.
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,038 PRO
    I use mulitmateconnector featurescript a lot. It still loses the owner with a split (I believe), but its easy to create multiple MC's at the same place for each part. They can then be used to make the assembly simple and extremely reliable. (unlike fix + group).
  • Jonathan_HutchinsonJonathan_Hutchinson Member Posts: 145 PRO
    I solved it in the meantime with my own FS that just just creates a new mate, referencing a known mate, deleting the old one. feels clunky but a decent short term fix. One thing I don't yet see though is how to set the mate connector name from an FS string parameter. Surely it's not just to be left default as Mate connector 1?
  • jelte_steur_infojelte_steur_info Member Posts: 634 PRO
    @Jonathan_Hutchinson
    I was looking for the same function. to reassign the MC owner.
    I can't find an entry to the existing MC though, so I'm not sure how this could be done…
    Deleting and recreating is kind of braking the chain though.
    Moreover it's unclear to me, looking at the native code, how the feature name is transferred to the MC. it seems like it's in done internally, rather than exposed in feature script :-(
    Could you share/publish your script though for future purposes?
    I've found in the derive featurescript, there are special provisions for MC information (featureId's etc) so that may be of use for your specificic use case.
    mine is losing it's mate within the same feature tree, so I'll just make a sketch, use the reference geometery and move the MC down the feature tree to reference the sketch geometry as the original geometry is lost.
