How do I bend an extruded part?
joey_pasciuto365
Member Posts: 2 ✭
I have this blade sort of thing that I need bent the same way as the circle how would I do this? I drew a little line on the screenshot to show somewhat how I want the part to be bent.
As you can see I want It to bent the same way that the circle below it is.
As you can see I want It to bent the same way that the circle below it is.0
