How do i rotate an extruded surface?
mike_s328mike_s328 Member Posts: 4
I am trying to rotate the extrusion 45 degrees.
This way the holes are angled from the rectangular shape.
I am essentially trying to make a 45 degree spice rack to hold household spices.
Thank you
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 949 PRO
    You could use the extrude direction option to angle the direction of the holes, but that's probably not what you want.
    You could also create a plane 45 degrees to the rectangular shape and extrude from there.
    Might be cool to chamfer one edge before you do your cuts.
  • mike_s328mike_s328 Member Posts: 4
    I was able to make a 45 degree plane as instruction, but now i don't seem to understand how to move my sketch to the new plane? Any help? @Matt_Shields
    Notice Plane 1 has to be before Sketch 2 in the Features list in order to move the sketch it onto the plane.
