Cannot find document to make Assembly
Hello. Recently I had trouble with importing a part from a partstudio into an assembly from the same document, because it would not show up in the interstions. I found that if the part does not have connected parts, you will need to make it into a composite part to put it into an assembly!
I wanted to share this because I spent a long time figuring it out as a begginner. Hopefully this helps someone!
