flat head fasteners - mate connector is on the vertex of the conical face?
Andrew_Netherton
Member Posts: 21 PRO
in General
The mate connector location for flat head fasteners has confused me since day 1, but it finally dawned on me that it represents the vertex of the cone of the mating face, and that I should be selecting the same in the mating part. I believe this works, but just wanted to get some confirmation from others AND document this for other newbies to find. Is this the intended use of this mate connector?
S1mon
Member Posts: 3,960 PRO
The vertex of the cone is the most accurate mate connector location.If the holes were created with a pattern or they’re all identical geometry, replicate should work, but obviously you can’t replicate based on a single face the way you would for a pan head screw.Simon Gatrall | Product Development, Engineering, Design, Onshape | Ex- IDEO, PCH, Unagi, Carbon | LinkedIn
1
A truncated conical face produces four separate MCs: one at each end of the of the cone segment and one in the middle (just like a cylindrical face), and one at the tip of the cone, which is the one you want.
When using replicate you will have the option to "match faces in part" (i.e. will replicate fastener to every identical countersunk hole in the part), or match individual faces (where you can pick identical countersunk holes).
