Mate Connector made with Transform unable to be hidden in model
Nathan_KadriaNathan_Kadria Member Posts: 6
When working in a parts studio, I noticed that I'm not able to hide one of  mate connectors using "Y" like I usually do. This only happens with a mate connector that I created by using a transform feature with copy part enabled. I can still hide the mate connector by hiding the transform feature in the feature tree, but I cannot mouse over the mate connector in the model and press "Y" to hide it. Is this intended behavior?
Thanks
  • S1monS1mon Member Posts: 3,957 PRO
    Unfortunately yes.
  • stefan_nilssonstefan_nilsson Member Posts: 13 ✭✭
    I have a related problem. I trying to create a number of extrusions of different lengths with a number of mate connectors placed 10mm from both ends. In order to make a compact structure i first extruded a 10m profile, added the connectors and then patterned both the profile and the connectors. I then extruded the profile to half the desired length and used the end plane to mirror both the remaining profile and all the connectors. This worked fine on the original but when trying to apply this to the patterned copies i wasn't able to select and mirror the patterned connectors
