Why is my extrude not working?
russell_gilletterussell_gillette Member Posts: 4 EDU
On my project in Onshape, I traced a Mustang Gt500 badge for my Dad. But, when I tried to extrude it, it did not work. Here's the link to my project, https://cad.onshape.com/documents/e254eb840338299bc95ebe99/w/858c59ae78eeaf2e57c05224/e/857e2b9ab303e524f79f1f77?renderMode=0&uiState=65ec1cd5e963876350652ac5. Someone please help me.
  • S1monS1mon Member Posts: 3,982 PRO
    You'll need to make the document public. It's not possible to make a copy to do any editing as it is now, nor can we see what selections you made for your extrude.
    The sketch is way too complicated. Try breaking things down into chunks, and use fewer points. If something is intended to join in a T, you need to make sure that the endpoints are constrained to be coincident. There are a bunch of spots where it looks like the curves are intended to make a T, but from selecting the faces you can see that Onshape is not seeing distinct regions.
    Here's one spot where I made a single click, but it looks like it's selecting two faces. That tells me that you don't have the endpoints constrained correctly.
    Similarly this is one click, but the area around the eye is included.
    There are some sketch faces which look like they should extrude, but it's not clear what your intent would be. Does this get turned into a 2.5D part with various depths for different details?
  • russell_gilletterussell_gillette Member Posts: 4 EDU
    its all going to be one extrude no various depths
