Creating relations between dimensions
gustavo_chellesgustavo_chelles Member Posts: 2 PRO
Hi, I would like to create relations between dimensions, something like d2=d1+3, but I don't find the way of doing this.  Can anyone give me a tip?
  • jelte_steur_infojelte_steur_info Member Posts: 593 PRO
    Hi gustavo,
    this can be done using variables:
     Create a variable named 'd1' (it'll appear in the feature tree)
     In a feature or sketch, you can type a formula. type "#" and you'll see a list of parameters you've created (you can even create one there and then).
    when you type in a sketch for a dimension "#d1 + 3" it won't work because it can't add numbers to millimeters or inches.
    so type "#d1 + 3 mm" and it'll work.
    you can also go ahead and create a new variable. name it "d2" and the value can be calculated.
    good luck
  • robert_scott_jr_robert_scott_jr_ Member Posts: 690 ✭✭✭
    Hello Gustavo. Create a variable named d1 and assign a value to it. If the value is 2 and you are working in inches It will look like this: #d1= 2in   . Now you can use d1 in the equation for d2 but you must add a unit type to the 3. When you are beginning to enter d2's dimension, hit the pound(#) key. This will call up a list of created variables and you can select d1 and go on from there. d2's dimension should look like: #d1+3in - Scotty
  • Ashley_DowleAshley_Dowle Member Posts: 2
    Any idea if this is going to be addressed? It seems a bit crazy to me that I have to create a variable external to the sketch. Often I will just want to make another dimension half of the referenced one (for example). I would not want the referenced dimension to have a representative variable cluttering up the variables table, which I would generally reserve for significant parameters. I've not used a CAD program that does not allow other dimensions to be referenced within the sketch.
  • S1monS1mon Member Posts: 3,751 PRO
    For something as simple as one dimension being half another, I just use construction lines as necessary and set them to be equal.
  • martin_kopplowmartin_kopplow Member Posts: 1,067 PRO
