Answers to Exercises
danilo_dias
Member Posts: 1 ✭
Can the answers be posted somewhere so that we know if we're off because we have too much material or not enough? If I'm wrong by a little bit (i.e. forget to add a Flinge) or by a lot?
I feel like a lot of the descriptions of the exercises in the Learning Center are unclear. I imagine this is by design, because it has forced me to do the same thing over many times, hence really learning the contents.
It gets really frustrating after to start something from scratch 3x in 3 different exercises, get wrong answers, and having no idea where things went wrong.
Thank you.
Thank you.
Hi @danilo_dias, that's good feedback and we'll work on it. Is there a particular one you are stuck on that I can help with in the meantime?Noa Flaherty / Customer Success / Onshape Inc.0
I echo this comment. No Idea how far off I am on this. Just completed the Gripper exercise and not sure if the gripper should be one or two parts for example I made it two parts because the pads would likely be made of a different material in the 'real world' still adding for both I don't know how close I am-- my shape may be just slightly different than what you intended.0
I agree as well. I was off by .001 in one of the problems and would have just moved on if I knew it was so close. Instead I went through the Public documents to find a correct version someone else did to verify where I made my mistake. Took a lot longer but still good practice0
